It is currently Sun Sep 14, 2025 1:18 pm
 Post subject: remove 2 sided tape
PostPosted: Mon Feb 22, 2016 6:39 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Today I glued my bridge on a tenor uke
I used 2 clamps with a caul both inside & out.
I used some 2 sided tape on the inside caul in order to keep in place white I positioned the clamps.
Too clever!
I cannot remove the inside caul which is approx. 3/4" x 3/4" x 3"
I made a L-shaped block & tried to knock it with a hammer, didn't work
I'm wondering about using some kind of solvent though it will not be easy applying it where I need it.
please help!
Mike McNerney
 Post subject: Re: remove 2 sided tape
PostPosted: Mon Feb 22, 2016 8:25 pm
Naptha will release it.
These users thanked the author SteveSmith for the post: Hesh (Wed Feb 24, 2016 7:35 am)
PostPosted: Mon Feb 22, 2016 10:21 pm
+1 on the Naptha
PostPosted: Tue Feb 23, 2016 4:05 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Walked in to the shop with the naptha method on my mind & the caul had just 'popped' off
thanks folks
Mike McNerney
PostPosted: Thu Feb 25, 2016 7:25 pm
You probably should still remove any adhesive residue.
You are lucky it came off. I did a similar thing 20 years ago under the bridge extension. The block is still there. At least it has no acoustic effect.
